07 nnbs Tahoe stabiliTrak prolem
AppocAlexx
Darth Appocalexx
Abilene TX
I recently bought an 07 LT Tahoe 4x4 and the work i know that has been done to it is a speed sensor and hub bearing replace on the front driver side. After driving for a few miles in slush and rain i hit the brakes and my traction control light starts blinking. Thinking im loosing traction some where i slow down more and the knowledge center starts saying to "service stability control" it said something else as well but i cant really remember right now. This morning it did not come on as i was not in any bad weather and did not end up hitting the brakes even as close to as hard as i did last night. Any thought on what this may be?
I believe that on these SUVs there are 4 different sensors, one on each wheel that the stability control/traction control work with and then in turn goes with your engine to kind of stall it out or just reduce the power in order to help you keep from sliding around. But being new to these im not positive on all the tech on them. I will try and run some codes on it and see if anything comes up soon and see where that leads me but im not sure if i will even get any if i dont have a check engine light on.
thanks for the help.
-Alex
Bsgiffor
If you read around there are a lot of posts that have to deal with service stability trac control. And the tricky part is that light can be triggered by a ton of things including minor things that aren't even worth addressing to major issues with higher mileage trucks who may stall after long drives due to worn vvt tech inside the engine. Like you said... check the code and hopefully it's no big deal.
Sent from my SM-S920L using Tapatalk
TLS3
