07 yukon air ride adjustment
55belairtim
Supporting Vendor
if your only looking for 1" drop shock ext and adjust the air ride sensor rod.
Cooter
So, all I need is shock extenders and to adjust the air ride sensor rod to get 1" of drop?? Can you please give me more info?? I don't understand how all the suspension components work hand in hand, but won't the stock springs still be holding the rear end up?? If you help me out, I'll get what I need from you, which sounds just like shock extenders but it's better than nothing. Thanks in advance.
Ben
05Yukon
Houston
No when my 05 autoride was in the shop they took the compressor out and the rear was sitting just a hair lower than the front. The shocks hold it up unless the autoride fails and then it sits on the springs.
Cooter
So how does a guy go about adjusting the autoride??
05Yukon
Houston
I think you can get shorter rods for the rear sensors. I have heard of people bending them a little also to get it to sit lower.
Maxpower_454
