08 Denali AWD FRONT DIFF mount issues
rscalfani
Hey all,
I've done as much searching as I am capable of and maybe I'm missing it, but the front diff mount on my AWD Denali is shot and needs to be replaced. Has anyone done this? What part number do I need? It's a vertical mount near the pinion off to the drivers side. I'm babying the truck, but it needs to be replaced soon. Any help with this would be a huge help.
Thanks!
randeez
south florida
i cant see how it needs to be replaced...there are some rubber bushings where it mounts to the frame that i guess could wear out but otherwise there really should be much movement.
just had mine all apart, you will probably have to drop the diff out or most of the way out to get the bracket out. drop both cvs, pull front driveshaft, remove crossmember under engine, support front diff, remove 4 mounting bolts (2 each side), easiest way i found to remove is lower the passenger side way down first and then the drivers side has room to drop, two people make it a whole lot easier - one person on jack, other guiding it down
i doubt there is room to just loosen the 4 mounting bolts and snake the bracket out
Ejwr
