VB90
so i had hard start isue for a while tested feul pressure and only had like 14 psi i dropped the tank to find the pump and filter were completely plugged..l a friend had an after market pump installed... now im getting no fuel at the rail... no power to the fuel pump fuse NO20 i think and i have voltage on coming into te switch leg of the relay but no power to the coil side where should i check next??
starnuts28
