it's easy to know i the engine is clean or not is floating carbon/sludge on a fresh oil change. that means you got a lot of crap in the oil panTry to determine what kind of oil was used in it and if the crankcase and or valve covers are sludged up inside. Reason being, we've seen so many guys on this forum but a new used truck and change the oil to synthetic. The synthetic cleans out all the sludge and causes all kinds of problems. Go slow.
this is what oil looks like after 500 miles on the oil change, see Zero consumption .
You can see the clean clear oil fluid. = Zero sludge in the motor
excellent oil pressure
reading 49-52PSI hot 70-73PSI cold
High oil pressure is required for the active fuel management to work correctly
49-52PSI is the baseline for a functional Active Fuel management..
if your engine cant meet that requirement you probably should disable it...
Mind you this is low duty use.. ( we have city highway speeds 40-60mph)
I don't rev up the engine,take off and keep under 1700 rpm mostly 1100-1400rpm range.
with the 6.0L VVT
(Only if necessary then i will higher rpm it I cap my self at 2500rpm) i.e to get on the freeway you generally have to match the speed of other drivers.. that is a point when it's "necessary"
i'll take a peak under the suv to see what oil filter it has..
it would be nice for others to report there PSI and if it works correctly
so we could get an average of what works and what does not
