08 Yukon Denali Eibach lowering kit and Auto Level problems?
MonoAnt
MonoAnt
Grand Rapids MI
id get some 10x24 machine screws cut of heads and replace oem one.
I think they are the right linkages because im not getting any service ride messages or would this not get affected. Do you sell shock drop brackets?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
have you sprayed soapy water on the bags to see if they work?
MonoAnt
MonoAnt
Grand Rapids MI
Yes the bags work. When I turn the ignition on the compressor does the 4sec cycle and the bags will pump to 20psi and I loose a psi every 3min or so which is within spec I beleive but it will leak down over time to 3psi and the compressor never kicks back on to pump them back up. Correct me if im wrong but I thought they were supposed to be above 10psi and if they get below that the compressor was supposed to run. Do u think the shock drop will fix this somehow or do I have more issues.
Frozen
Looks like I'm stuck with the eibach kit. Amazon already shipped it and won't take it back unless I pay shipping. Not viable for me from Alaska. My kit does include new sensor rods. I'm going to order rear shock extenders and live with it for now. There is always next year......... Lesson learned, no more impulse purchases. I'll try and post the install manual if it will help. :sorrysign:
MonoAnt
MonoAnt
Grand Rapids MI
I think you will be fine with eibach as long as you buy the stuff they dont provide. Post that install manual if you could. Thanks
08grey
There is a set of shock extenders here for sale somewhere.
Delly
So every time you turn your key to on not starting, it's suppose to cycle thru and fill with air?? I don't believe mine cycles every time and I'm pretty sure it has to be running, I have a 2011 tahoe Ltz. I did the rear belltech leveling kit and my problem is the rear sits lower then the front just about a inch.. Gonna try to use the stock air ride links and go from there..
MonoAnt
MonoAnt
Grand Rapids MI
my 08 cycles air everytime you turn the key on. Im pretty sure its supposed to. BUT my buddy has an 11 and his doesnt come on when the key is turned on. I think this is a change gm made after 08
Frozen
I will screen shot the manual and post since the PDF is too big to post. Manual is 3 pages long.
Frozen
See if this works.
SSVTahoe16
