08 yukon denali i cant pump gas
flako1
Houston
I just replaced most of the evap system in my yukon and I still having trouble pumping gas it might actually be worse now then it was before can anyone point me to the right direction??
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
So "still having problem" means you had the same problem you have now, correct? What parts did you replace and please tell me you used Genuine GM parts. "Most" of the evap system means what?
F
flako1
Houston
Lol sorry I mean I tought I fixed the gas pump issues but some how it's worse now and I replaced evap canister harness and solenoid, the evap purge solenoid, gas cap I cleared out the lines did have some charcoal not much
olliec420
What the procedure for blowing out the lines?
I got 09 Yukon and it won't take gas. I disconnected the vent tube from the canister to troubleshoot for blocked can or solenoid stuck. It still won't take gas. Could be charcoal in the vent line to the tank? It doesn't looks like fun trying to disconnect from the tank to blow out. When I put gas in (even with the vent hose open to the atmosphere) the fill hose fills up and then I can hear it running down in the tank and sounds like the air is coming up the breather. I don't know what's going on. Did you get yours resolved?
Loose_Gasket
