1" front drop? Key adjustment only?
Dan Acosta
I tried to find a thread on this, but couldn't find exactly.
I only want to drop the front an inch. (rear drop was a hair too low for front)
So can I just do it with key adjustment?
Will I need to align after?
Will my ride be effected?
cmc76
i havent done it yet. But its on my list when i swap coils. I believe you can get an inch, and yes it will need an alignment.
D
Dan Acosta
Just finished, 2" rear coils and turned the front keys 4 turns each. Got about 5/8 in the front. I plan on driving around a few days, then I will re-evaluate. Also to take a few days to get used to the look.
01ssreda4
Can get about 2 inches of drop with the front keys, I like to take the weight off the wheel that Im adjusting before i turn the bolt.
D
Dan Acosta
Update, Drove around a bit today, and the rear ride is pretty rough/harsh. I would not have imagined it being so stiff with a 2" spring. Perhap, I need to adjust my bumpstops. I also added the shock lowering mounts because I have air ride. The kit came with shorter sensor rods, which I have not yet installed. Maybe these would help with the ride?
haloOne
