10 ply tires on a 1/2 Suburban?
BigDaddy13440
Rome, NY
Currently have General Grabber AT2's in LT285/75/16's, have run them at NO LESS than 45 psi in the winter, currently have them at 50 psi for the rest of the year. Probably giving up 5k in mileage wear, as the centers have about 2/32nds of an inch less than the edges.... but I personally like the feel of a stiffer sidewall. I've driven trucks that the owners have kept at 32psi (as per manufacturer's recommendations....WTF!!), and it seems like they wallow badly through turns.
I'm sure when I put the 20" Denali wheels on, the shorter sidewall will be stiffer, and I won't HAVE to run them at 50psi....
Wife had some Michelin E rated's on her '98 Expedition. Ran them at 70 psi year-round, got over 65K on them, and they were on it when we bought it.
Matahoe
Grand Rapids, Michigan
The spec sheet shows the maximum load carrying capacity using 80 psi. Capacity drops as psi is reduced. Lets just say I need all of that capacity.
dirtydenali07
Stay away from C load range tires. They are not meant to carry the weight of our full size SUVs. Do the research on the LT C's and compare the load carrying capacity to E's. every brand/style of tire is different.
Why full size trucks and suvs ever came from the factory with P tires is beyond me. My brother in law has a '11 1500 sierra and it had P265/70 17 on it. I bought him used LT 's in the same size. He works for a contractor installing flooring and he has to carry the materials sometimes. I even bought him air shocks for the rear after he sent me a pic of the squat with the bed loaded. Maybe he should have bought a 2500.
thunderdawg
Prescott, AZ
I put LT load range E tires on my 1996 Tahoe after one too many sidewall punctures from greasewood where we hunt in WY. The corral legend is the tougher sidewalls resist the greasewood. Now I have a 2016 Tahoe with OEM tires. One season so far with no punctures. BTW, as others have stated, the tires can handle up to 80 psi inflation pressures, but I ran 40 to 55 psi to avoid wearing out the center treads since most of the miles were with little or no load.
My99Yukon
I have been running 10ply 265/75/16's for years and when I am loaded down I will routinely put 60psi in and it feels fine, not too harsh, and gets better mpg than running down at 36. I put poly bushings on body mount, motor, transmission and sway bar. It definitely makes for a firmer ride but I love not having a marsh mellow and the piece of mind of the 10 ply when I am off road.
I will do a torsion key lift and put 285's in when I need new rubber but for now the 265's are a good compromise. check out the rest at the Project 99 Yukon.
Matahoe
What is your trailering capacity with that truck?
I did some research. It looks like trailering capacities for most Chevy Tahoe and Silverado 1500's from 1999 until 2009 without 4.10 gears are around 7600 lbs. My trailer is 7800 lbs dry (empty) from factory and guessing about 8600 loaded 1200 lb tongue weight. I am now possibly thinking of getting a 12,000 lb Equalizer hitch. The one I currently own is a 10,000 lb Equalizer. 2500HD trucks are heavier on the whole. The best deal seems to be the 8.1 liter 2500 variants. A 8.1 liter 2500 Avalanche looks like a good contender.
Matahoe
I know for sure there is a high side, just can't find reliable info on what it is. Some say 44, others say up to 85. Just was curious if you got at alarm at 80.
I filled my tires to 75 PSI today and towed our trailer for a few hundred miles. The TPMS never even alarmed when the pressures got to 82 PSI on the DIC. I am thinking there is no upper limit. And if you think abut it..why would there be? TPMS is designed to alert the driver that the tires are low.
SinStar999
