14” lifted 07 Silverado build
Trey Hardy
Trey Hardy
Eastern North Carolina
2007 Chevy Silverado
Mcgaughys 7-9” lift set at. 9”
Mcghaughys traction bars
3” body lift
2” leveling kit with icon coil overs
Lift set around 13.5”
Fabtech uniball uca
Showtime metal works bumpers front and back
C bar led taillights
Color matched led third brake light
Color matched tow mirrors with led switchback turn signals
Custom retrofit halo projector headlights with switchback halos and strips
12 piece rock light kit in the fenders
Kryptonite wheel hubs
Heim joint tie rod ends
Hummer style apex chassis inner tie rods
Dirt king fabrication locking alignment cam plates
24x14 fuel forged wheels on 35/15.50/24 venom power tires
Trey Hardy
Trey Hardy
Nothing new really I swapped in a 2500 grill I still haven’t painted my bushwacker fender flares to put on it I still need to order halos so I can put new headlight lens and halos in the headlights
Trey Hardy
Trey Hardy
I did wire up a 2500watt amp with a old Rockford fosgate T1 15” in a ported box I got it in the back floorboard of the passenger side with the seat flipped up it gets down for what it is I can’t keep the rearview mirror from falling down
Trey Hardy
Trey Hardy
Did a wheel bearing and front brake pads last week along with a broke. Transmission mount on the tail shaft of the transmission AND currently getting the rear end rebuilt where that fell apart on me…
Posi and 4.56s are on the way!
Trey Hardy
Trey Hardy
Got the rear end built
Tru trac posi with 4.56s new bearings and seals and new silver diff cover
Got some coil overs from @randeez i threw on there
I also redid the headlights luckily the halo I thought was burned out isn’t it was just the switchback driver that went bad and another one has a loose connector I may swap the plugs on it for a toggle style male and female wire connector for a tighter connection and see if that fix’s it.
I still need to get the demon eyes in the projector hooked back up
Haven’t done much besides that stuff
I did do a rear diff fluid change after the break in period was over and a much needed oil change but that’s about itIMG_9600.jpegIMG_9588.jpegIMG_9572.jpegIMG_9571.jpegIMG_9570.jpeg
grass209
