Lowered our '15 Taco LTZ. Used the McGaughys 34213 kit. Advertised 2" drop spindles in front, and 3 springs in rear. Install was straight forward. Took about 2 hours to do the front and about 45 minutes to do the rear. I did this in my garage at home using standard tools, jack and jack stands. No special tools are needed (spring compressors, ball joint tools). This was my first time lowering a vehicle, but my mechanical abilities are probably a little above average. Instructions included in kit are accurate and easy to follow. I like the way the front turned out. The rear still looks a little higher than I would like, but as I write this, the kit has only been installed for an hour. So, Im hoping the rear will settle another inch or so (fingers crossed)
Before
After
Before
After
