Got the Xineering kit and Monroe parts in today. Won't be able to get to until the weekend though.
Sent from my Pixel 3 using Tapatalk
GREAT CHOICE!!!
Going off of my own experiences with the Xineering GM Shock Sims MRC delete sensors -> take some extra time and carefully read through their provided instructions and watch the installation YouTube videos.
Also, a little wd40 or similiar lubricant may make unplugging the existing circuits a bit easier, careful not to damage the plastic locking clips.
INSTALL: http://shocksims.com/images/Kit_Install_Current.pdf
INSTALL VIDEO:
AIR Bypass Instructions: (if you install MRC delete sensors on the rear AIR suspension)
http://shocksims.com/images/ALC_Bypass_Guide.pdf
Ride Height Trim Procedure:
I had this procedure performed at a Chevy Dealer here in Maine approx. 100 miles after installation and paid $90. They did NOT provide me any proof of completion or any visual data regarding voltage readings. Working with Max @ Xineering, we determined that my front left ride height sensor was possibly damaged. He sent a new circuit, which I installed on my own, and I then ran the Xineering software on my laptop to read & clear the DTCs that had been thrown with the "Service Supension" warning on my dash. I was able to visually see my LIVE voltages going to all 4 corners and then ran the Ride Height Trim Procedure. It's been over 5,000 miles and I have not seen another "Service Suspension" message.
Xineering's website states "While the Ride Height Trim Procedure is recommended on the SUVs when bypassing the magneride. It MUST be performed on the Sierra Trucks. The suspension calibration of the Sierras is much more aggressive than the SUVs, without the trim procedure our shock sims will fail in a few hundred miles. There are scenarios where the SCM (Suspension Control Module) could damage our shock simulators with current (mA) and causes them to fail.
If you have ever had a leveling kit (OR ride height sensor) installed at the dealer or shop, and a Ride Height Trim Procedure was performed, then the values in your SCM are NOT STOCK.
If the new RHS simulator voltage is drastically different than the original one then the SCM will send current(mA) to that shock because it thinks it needs to be adjusted.
We can loan a scan tool to the customer with a new kit and perform the ride height trim procedure following our PDF instructions."
Images from the Xineering software module:
Informational handout I received when Xineering sent me the cord to plug into Tahoe's computer:
