18s or 20s
Zed 71
Pacific NW
Yeah I was really surprised they required that much trimming. I do think it makes a difference MT vs AT. I take it off-road at least once a month and I do flex the suspension to its max while at full lock.
BTW did you measure the width of your BFG ATs? I am just curious what the difference is. It seems like people installing BFG AT 285/65/18 do not have a problem (very minor rubbing), but other tires (especially MTs) require trimming.
UofMZ71
no but i can go check it out now...
whats your MT width?
Zed 71
Pacific NW
I will check mine when I get home too. I recall it is 11.2X". Very close to the theoretical 11.22" (285 mm).
2 E L O
Omaha, NE
I'm a little curious how my 285/70-17s are going to fit when flexing offroad. I don't do much offroading so I'm not going to worry about trimming anything yet. Normal driving, even at all lock and pulling up the slope up into my driveway I don't have any rubbing....but I have yet to check the sway bar as mentioned in a separate thread.... :shrug:
UofMZ71
yeah 2ELO i havent checked the sway bars either! ha oh well, guess ill be looking this weekend. i would like to take the truck off road but just really havent found the opportunity.
im measuring from side wall to side wall and getting about 11.25 or maybe a tad more, BUT i also have the tires at just under 40psi as i hated the DIC telling me i had the tires too inflated at 48 psi and dont want to spend $200 to reprogram!
T
TREYR8D
Hmm....I dont want to have to trim that much, may just have to stick with the 285's. That still gives me an extra 20 mm over stock tires. I think if i just go with the 20x9s instead of 20x10s it'll give me the exact same look, tire on the rim. Prolly try to match stock offset/backspacing so they wont stick out at all.
UofMZ71
yeah that seems like a good plan, im not a big fan of tires that stick out, but the one good thing about the Z71s are the fender flares so having a bigger and wider tire doesnt seem as awkward... not that any of the other trucks here look bad! just not my taste...
DaisyGirl
