1992-1998/99 SSBC Rear Disc Conversion
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the nbs helps a bit when you put the conversion in and help to reduce the spongy brake feel. problem is the booster hole needs to be machine wide to accept the mc. a bit tricky to make it work but it does.
YUKON1999
YUKON1999
How hard of install was the hydro-boost system cuz I want to do that next
DIAZ-does your brake lines leak in that little transfer unit above the rear diff?
DIAZ
Install isn't that bad as long as you have all the right parts. My bolt it right up, but since my hydro-boost came off a vortec motor the bracket to the power steering pump had to be swapped, which is why it took longer. You will definitly feel a difference. And no I don't have a leak on mine.
YUKON1999
YUKON1999
how much did you pay for the hydro-boost system if you dont mind me asking and did you do a big brake upgrade up front?
YUKON1999
YUKON1999
just trying to get my ride to where i want it but it seems like that never ends
cuz ill see something someone else did to theres and i like it and want to do it to mine
DIAZ
I didn't pay anything for my hydro-boost, and I didn't do a big brake upgrade on the front. I'm thinking of getting the ssbc front calipers but not in a rush on that.
blanchard7684
