1996 Tahoe P1441 Troule Code
jbry31
Indiana
I have a trouble code P1441, it does not stay on constantly and some days does not ever come on. Any advice, solutions, and experiences with this trouble code.
Thanks! Working on my profile. I will try to be an informative person and also help other peopple out. I love you Tahoe and love working on it. Will be making the Tahoe my profile picture soon
laredo1307
Most likely a faulty gas cap or you left off. Make sure it's tight and give it a few days to reset. Or you can disconnect the negative terminal for a while and let it reset, then see if it comes back.
jbry31
jbry31
Indiana
Ok, I have been told it may be a faulty gas cap. May buy a new one and see what happens. SES light has not come on today but was on yesterday. I have disconnected the battery several times and still comes on sonetimes.
jbry31
jbry31
Indiana
Purchased a new gas cap tonight. The SES light was off when i replaced the gas cap so now it is a waiting game to see if this is going to remain a cheap and easy fix.
jbry31
jbry31
Indiana
Thought it was good to go and an easy inexpensive fix...we all know its never that easy. Tonight the SES light came back on. Any more suggestions?
Thanks for the advice so far.
laredo1307
http://www.tahoeyukonforum.com/forum/showthread.php?t=32353
Here's a link to someone else who had the same problem. In my opinion this probably will not be the fix either. Most likely you have a drop in pressure from a leak some where in you fuel system. Maybe you fuel pump is cracked and letting fumes out of the gas tank or the hose from the gas tank to the filler is deteriorating and you losing pressure. Most likely your best bet is to take it somewhere and let them do a smoke check and see if they can detect the leak. Otherwise you be replacing one little part at a time not knowing if it's the right one.
jbry31
jbry31
Indiana
Tested the purge solenoid valve and it tested faulty. Installed a new one and all is good! No lights, truck is running better.
---------- Post added at 12:54 PM ---------- Previous post was at 12:53 PM ----------
Have anyone heard of having overdrive shifting problems with this code? Before I changed the PSV my truck sometimes wouldn't go into overdrive. Now after installing the new PSV it shifts flawlessly! Does the vacumm affect the OD?
Njoppy
