1996 to 1999 Frames???
skippy
Hey All,
I'm a newbie to the forum, but no newbie to wrenchin' :) I have a 1999 Yukon that has very low mileage, but the frame is bad. (dude must have been dipping it in salt water or parked it in grass) I've found a 1996 donor...will it work as a direct replacement?
Thanks in advance for any and all advice!
Cheers
John
Gzes
the drifting 2dr
Wichita tx
Is the donor a yukon also? If not then i wouldnt do it cause the could be different. The suburban is longer. I would say try to find new. I think they dont go for that much.
S
skippy
It's the same truck, just 3 years older. I'm in Nova Scotia, Canada so finding a good used frame, or a new one for that matter, is challenging. I'd much rather not have to go through the dis assembly of the donor though...so any suggestions where I might find a new one would be appreciated!
Administrator
If it's the same truck just three years older you should be good :waytogo:
Gzes
the drifting 2dr
Wichita tx
Wait didnt lmc sell frames a while ago? I coulda sworn i saw one a while ago
purple 'hoe
Green Bay, Wisconsin
I'd only assume it would work. But honestly, not 100% sure. But anything is possible
Just make sure that the frame was from the same body style as yours. So if yours is a 4 door Yukon/Tahoe, then make sure it's a 4 door frame. The 2 door frames are different along with the Suburban frames
valentinitoronto
