1997 GMC Yukon Build Thread
97YukonNZ
97YukonNZ
Okay so that was short lived .
Is all back together.
I thought I had a G clamp that I could modify and use to wind the key up and release the adjustment plate.
Seems I lent it out and was never returned.
Do I need a proper clamp?
Can I use builders or woodworking clamp and knock the flat plate off so the ball sits in the depression in the key?
Only asking as I can get a builder's clamp easy
Have called all over town and no one has an automotive 1.Screenshot_20240129-174530_Trade Me.jpg
Have called all over town and no one has an automotive 1.View attachment 420167
Wish I had an answer for you. Maybe @iamdub Would know.
97YukonNZ
97YukonNZ
Thanks Tony
I had a look online and compared the clamps.
It is a Specialized tool that takes all of that key torsion torque.
No other way apart from the right way.
$370 shipped from Rock auto
$170 shipped on Ubuy
$400 shipped on Summit
Sheesh ayyy!
Thanks Tony
Sheesh ayyy!
You'd think you'd be able to rent that tool from a shop or parts store.
97YukonNZ
97YukonNZ
Have bitten a bullet and splashed out for the cheapest option I could find.20240130_084640.jpgFound this on Ubuy for $171.00 n.z and that included the shipping cost of $76.00
It is getting expensive owning a foriegn car!! Haha :burnout:
I cant just go down the road and pickup so new bits.
And lol talking about new stuff! I have been getting a bit of vibration or reverb/rattle on front left through potholes or corragations in the road.
Yesterday when I was looking at swapping the keys I checked out the top & bottom arm bushes and they are looking tired and 1 is starting to split the rubber bushe so that is a job to do! Yay!!!
Will have a performance front end by the time I'm done.
Rubber or Nolathane??
Have bitten a bullet and splashed out for the cheapest option I could find.View attachment 420240Found this on Ubuy for $171.00 n.z and that included the shipping cost of $76.00
I would've asked the same as Tony- The major auto parts stores here loan tools. It's really not even a rental. You buy it under the loan-a-tool program and get your money back when you return it. Maybe that's not a thing down there.
As for bushings, polyurethane is really stiff and you'll feel, if not hear the difference. Unless this sort of thing doesn't bother you, I'd stick with rubber. Or, split the difference and use rubber on the lower control arms and polyurethane on the uppers.
97YukonNZ
97YukonNZ
Yes I would have thought I could at least rent 1 here. I think if I had booked it in somewhere to get them fitted they would have the tools.
Thanks for your thoughts on the bushes. I will take that knowledge on board and use when I do the replacement.
97YukonNZ
97YukonNZ
I am just having a look at these leaf spring hangers that I purchased along with the keys.17065786934863665000431017043226.jpgAnd while I was lying under here yesterday I was contemplating the change out of them.17065787929171504736493899448821.jpgOn the drivers side here I am thinking I need to run her low on gas and undo the tank straps while supporting the weight of the tank so I can get either the nuts or the bolts in there when installing the new hangers.
Anything I need to look out for with the tank? Disconnect the filler and breather hoses?
I will drop the spare out and have a good look at it before I start the job. I will be patient and do the front 1st!
Lol it will be Feb 20th before the key unloading tool gets here and I dont want to be seen getting around like thisFB_IMG_1620866979625.jpg
97YukonNZ
97YukonNZ
Okay so I've decided while I'm waiting on the unloading tool for the keys I would start the install on the hangers 17069285005469104871037473990020.jpgSo far so good! Have chopped both old hangers off. Going to buzz the surface rust off and paint the area affected.
While the paint dries I'm going to loosen the petrol tank straps off and support the tank. Only want enough room to get my fingers up in the so hoping that plan will be effective. :893karatesmiley-thu
FredEx112
