1997 Yukon having starting issues-Moved
vali31
Bay Area, CA
my 97 Yukon is not starting on its own. It cranks but won't start unless I spray some STARTER FLUID in the throttle body. When it starts it runs fine. It has not died ever since this happened 4 days ago. I had the spark wires replaced yesterday and the plugs about 2 months ago. The rotor and cap were not replaced.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Hey Vali, your fuel pump prime may have failed. When you turn your ignition switch on but not start it do you here the fuel pump running for two seconds?
Tssonebay
