2/4 drop what to expect??
NJ04HOE
NJ04HOE
Paterson, NJ
that's hot did you run into any issues with drop kit? how's the ride ? did you have to redo the alignment again ? What size tires are you running do they rub.
Sorry for all these questions but this is my next mod, I originally wanted to go with a 2/3 but after seeing yours look like i want the 2/4 now..
Thanks, no issues with the kit. I did have to have it aligned again and I have 305/35/24's with no rub. I must admit in the pics it doesn't look all that low but I really notice a difference in person.
DarkTahoe00
IN
I got a 2-4 Belltech drop kit on mine and my rear end did ride rough but I put Air Spring Helpers in, it helped out alot but I'm still gonna have to do the Free Travel Mod my bump stops are really close to touching I'm also running bout 5psi in the bags, I removed the bump stops to see how it was gonna ride and it hellva lot closer to stock ride now! Yours looks a little high still but it should settle down. Did you take measurements before lowering it and after you did?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
If you bought the kit used it probbaly won't settle any more.
+1
It won't settle because the springs are used. They are/have already settled. IMO, you rear shocks are keeping it up.
And you can probably take more of the screws out of your front keys to get it a little lower as well.
It looks ok, but a 2/4 kit should have dropped it more.
genevieve
Shadow
Gladewater, Tx
im going 2-4 as well. my shock extenders just came in the mail on saturday soo im trying to get her lowered by then end of the week but im not sure if itll happen. so we will see:)
NJ04HOE
NJ04HOE
Paterson, NJ
+1
I actually did have the front lower than it is but I put it back up because it looked stock with that nasty rake. What shocks should I use??
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Bilstein HD rear shocks f4-be5-6501-h0
Did you measure before and after to see how much the rear actually came down?
brucebruce45
i just did 3'' coils in the back of mine and i have no bumper, no 3rd row or spare tire an my rear is lower than that. u should check the shocks an see if somethin is holdin it up cuz it should be lower than that in the rear
titanium02
w7's or bust.
Norfolk, VA / ATL
I think i'm going to go 3/5... start saving the $$ now to do it right. Just don't want to spend over a grand.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I think i'm going to go 3/5... start saving the $$ nbow to do it right. Just don't want to spend over a grand.
Including shocks it can be done. Mine was just under $1000 not including the sway bars. $1100 including sways.
bruh2125
