2.5” lift 2023 AT4 Yukon
mcasey5121
Has anyone put the Rough Country 2.5” lift on a 2023 AT4 Yukon? If so, got any pictures? How did it change the ride? Any advice…THanks!
Rayse
I did it to a Denali with mag ride. Didn’t change the ride at all. Still need some tires. My only complaint is the upper control arm is super close to the factory tires so you may need an aftermarket wheel. IMG_7214.jpeg
djnice
Did you install it yourself? If so, how did that go?
I think others are using wheel spacers to deal with the upper control arm issue and fender rub with wider tires.
djnice
Installed RC 2.5 lift on AT4. Will post in mega lift thread. Lifted about 2.5" front and 2" rear.
Trey Hardy
Eastern North Carolina
The lower 2.5” leveling is super easy to install and only takes about 20-30 minutes with basic tools and a floor jack
Undo the sway bar link
Unbolt the bottom strut bolts
Jack it up enough to slip the spacer under the strut
Then reassemble it’s a piece of cake don’t pay no shop 200-400$ for a 20 minute job you can do in the driveway with your harbor freight 10$ socket set!
ProfeZZor X
High Country
Still my favorite new body style Tahoe on here bud!
I went with the 35's back in May, and I have to say that I'm not happy with the rubbing. I'm as far back as the frame (behind the wheel), and I still get some rubbing back there on the power running board LED clip. I'll have to make some modifications so that it clears the tire, but it's a pain in the ass that even after all this time, I still rub. I can always go back to the 33's but they look a little thin compared to the 35's, and don't fill up the wheel well as much. The ride is also nicer with the 35's, so I guess I'll have to break out the power tools again.
EDIT: I fixed the rubbing, which was the electrical chord on the power running board. I removed the end cap a few months ago to prevent more rubbing, so now I'm okay.
BigBodyBurban
