Tonyc
- Joined
- Oct 26, 2014
- Posts
- 14
- Reaction score
- 1
Can you get the 2 speed transfer case with 3:08 GU4 axle ratios in the 2015 up Tahoe
I just wonder if it has the NQH 2 speed transfer case does that automatically give you the 3:42 gearsI looked at the 2015 and 2016 Tahoe catalogs and it appears the 2-speed transfer case could be ordered as an option, separate from the Z71 or Max Trailering Packages.
About 99٪ of the time the 2 speed is with the 3.42 gears, because normally its paired with z71 and max tow...I just wonder if it has the NQH 2 speed transfer case does that automatically give you the 3:42 gears
Ok I found a 2016 suburban online and don’t have access to the option codes. I was hoping it had the 3:42 gears. As you can see from the pic it has the 2 speed transfer case but no trailer brake controller.
@Tonyc If you can get the VIN... I looked my VIN up at this link and one of the tabs had the correct diff ratio. Lots more info than the generic VIN lookups.
https://chevroletforum.com/forum/vindecoder.php
