20" wheels ET
Heldju
Hi. I’m planing to put 20" wheels on my 2004 Tahoe. What would be the correct ET to use on a set of 20x9" wheels?
HD
PG01
Up here to the right
Thats a new one to me. How does one get that from “ET”?
Offset is usually stamped or engraved into the wheel and is measured in millimetres of 'ET' (ET is the short form of the German word 'Einpresstiefe' which literally translates as 'insertion depth')
doesnt really exist tho because you never heard of it.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Thanks for the explanation on what ET stands for. Learned something new.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
ed70805
