Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Well, the light is coming in at an angle in that pic, but the tire is almost the exact same width as the outer fender. It doesn't stick out past the fender, but it's right there.
Running extenders on mine with OEM shocks totally changed the ride imo
---------- Post added at 12:03 AM ---------- Previous post was at 12:01 AM ----------
When using stock length shocks.......... The use of extenders is a must even on a 2 inch drop. The angle changes. I did this on a 2 inch drop and used stock shocks for 6 months.
I added extenders and I could see where the dirt line cutoff. The angle and the ride changed.
most of the guys trucks have over 100k miles on the older trucks. high mileage id rather swap out shocks but if they cant do that extenders. Best woule be both but not many people want to spend over 400 on extenders/shocks/springs from belltech
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
