Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I've started 3D modleing the release system for that pesky top lid latch.
(If you have a broken system? You know what I'm talking about!)
I found good pictures of the parts so plan to 3D Print them to fix my lid.
Think I may put "Bomb Release" On that button.
Today I remove that top lid so I can start the measuring for the parts needed.
I have none of the stock parts as the lid was screwed down and would not open.
The first part I make will be the slider latch. That way I can get the scale and find proper springs.
I'll also trace the shape of the visible outer contour and use that as a pattern in 3Ds Max to make the basic shape of the hold down system. And get measurements for that part.
Then I'll make the actual button part after that.
One thing I plan to do is make that hold down part WAY stronger! Just looking at the pictures tells me why they break.
I'll print in Petg for max UV resistance and temperature stability.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
