"I read somewhere it could be the knock sensor? Another thing Ive noticed is rarely seomtimes when i turn the car off in a parking lot, come back to it withint 5-10 mins turn it back on and pull out the parking lot and step on the throtle a little the car gets confused, as if it doesnt know Im pressing the gas, and then all of a sudden its like it catches and then takes off."
That seems like a throttle position sensor problem.
There's a test guide for it here.
http://easyautodiagnostics.com/gm/4.3L-5.0L-5.7L/tp-sensor-tests-1
Is the miss at idle more than 50 rpm? Is there no error code or check engine light?
I've also been told that throttle shaft bushings can be a problem if there is too much play.
Anyways, Good luck!
Anyways, Good luck!
