2001 Tahoe transmission issue
NickTransmissions
Sin City
The transmission bench
Just had a mechanic fix a leaking rear main seal 2 weeks ago. Could his pulling of the transmission have any impact on this?
Does the vehicle move at all under its own power in 2H, 4H or 4L at all?
We're using terms like "goes into gear", "goes into 4H or 4L" but that isnt the same as actually moving so be specific and explicit when describing your symptoms.
If you do have movement in 4L/H but not 2H then you have a transfer case or rear diff problem. If you dont have any movement at all, regardless of what range position you select on the shifter or transfer case shifter/push button selector then it can be either t case or transmission.
Aride
