2002 5.3 intake manifold gasket replacement.
sonic_the_hedgeh
I need to replace the intake manifold gasket on my flex fuel 5.3 Tahoe and I was wondering if there is anything in particular I should know about?
I did a forum search but I couldn't find anything.
Sent from my moto g(7) play using Tapatalk
I had my knock sensors replaced last year. So while they were at it got a kit of gaskets for 140 dollars that replaces all the intake manifold ones. I had quite a few that were shot. I would suggest you replace all those as well. It was worth it in mine had lean codes coming up. Now all good.
Sent from my LM-V600 using Tapatalk
R
R422b
Oklahoma
That's what I'm doing and the reason I'm doing it is because of those lean codes.
I should have everything to do it next weekend so hopefully we'll have good weather.
R
R422b
Oklahoma
These are my codes.
I really need to tackle the evap issue but I just don't have time at the moment.
R
R422b
Oklahoma
Am I going to have to do any crank cam correlation relearn after replacing the cam sensor? I think that's mostly a vortec small block thing but I wasn't sure.
R
R422b
Oklahoma
I was sure hoping to do this this weekend but I just called the dealer to find out where my parts were and the knock sensor harness is backordered with no eta. [emoji3525]
R
R422b
Oklahoma
I have some tuning questions about this Tahoe but I guess I should probably start a new thread for that.
R
R422b
Oklahoma
I still haven't got the knock sensor harness but I finally changed my fan clutch which was needing changed 3 years ago and was totally shot now. I also upgraded to the heavy duty clutch because it had problems with the transmission cooling and the ac at stops.
talking about Chevy's using Tapatalk
Alsherooqi
