2002 chevy-suburban 5.3 4wd p0300 Problem Need help
K
kamelred408
ok so i unbolted the driver side cat. revd it up and NO MISFIRE!
it started to misfire at idle but i only unbolted the cat i could not lower it to much so i think it is to close and causing back pressure still..... CAR SOUNDS AMAZING with an exhaust leak lMFAO
So i should have trusted my scanner and just got a new driver side cat. here in CALI we have special ones so its not cheap
I will replace the cat and get back to you all
THANK YOU EVERY 1
THANK YOU EVERY 1
Careful about buying those cheap Chicom cats, they barely last a year. I got mine from Magnaflow and they have CARB cats for you too. I went with a Y-pipe and replaced them both.
Larryjb
That cat failed for a reason. I've never had to replace a cat here in Vancouver where we had AirCare ( emissions testing) for decades. Your 02 should have lasted longer. It is possible the original problem was fixed.
I still have a gut feel about the intake manifold gaskets. If they are original, I'd replace them and check the knock sensors at the same time. (there is a tsb on the knock sensors).
CrazyCanexan7897
