2003 gmc yukon slt overhead manual climate control suppose to be lighted???
Summajet
I am trying to figure out if the manual/dial overhead climate control is suppose to have lights under the dials?
Mine is not lit at all.
Thanks!
S
Summajet
That is what I thought my overhead climate control should be lighted.
setconstr
Mine are, it's the rear overhead that's not lite on mine wonder if that is supposed to be lite also ?
JonnyTahoe
Minneapolis
Those are my pics of all the overhead Controls front and back. When your truck was new they were all illuminated.
DougAMiller
Colorado
There are 4 bulbs. They are soldered to the circuit board, so you need soldering skills to replace them. It's not too hard. White 12V LEDs can be soldered in place of the incandescent bulbs and should last forever. The problem with the original bulbs is that after a few years the filament becomes pretty delicate and just the jostling of removing the housing can break them on several other bulbs. So if just replacing burned out bulbs have a few spares because by the time you get it put back to together with the new bulb, you'll likely have another one or two out and have take it apart again (speaking from experience).
conrual777
