James417
My 2003 Tahoe has a rear access open message on my dash when the rear access is obviously shut tight. I cleaned the contacts and got them nice and shiny. Still says rear access open. Removed the contacts to look at them and test with multi meter and they where fine. So I'm thinking loose connections or BCM is acting up. I also have the lights stay on inside so I have to use the dome light override to stop that from killing my battery. Then when it randomly acts up and thinks the rear access is open if my rke alarm is set the alarm goes off thinking the doors open. And this happens at random times of day and night. Not only does it piss my neighbors off it also kills my battery. I also had my whole dash cluster die completely on me once. Nothing was working like no signal going to the dash cluster and the wipers and lights where acting weird. Then the battery again died and once recharged it was OK again, Just the random rear access open message again. So probably bad BCM but any connections I can check? I had my alarm go off 3 times in 30 minutes a little while ago and I'm ready to fix this because it getting pretty bad. Thanks in advance
