2003 Yukon denali Bad wheel bearings
T
TimWolve
Yeah and I just wanted to make sure because even on other sites it mentioned a range from 156 to 200 ft lbs, I was not to sure so I did not want to go thru all that work and screw something up. yeah I googled it but I kept getting different specs so it got a little confusing, sorry man was not trying to be a pain in the rear. you can google crap till you turn blue but in the end you get different answers so its hard to tell which is correct, figured id have a better shot asking on here where folks have done this before. guess I was wrong.
We are all in the same boat. No problem. Just razzing you. I just go by what looks legit.
Tahoe14
Central Fl
If you really want to get razzled you posted in the 2015+ section and not in the 2003 section but you still get help.
Tahoe14
Central Fl
Its all good, we are all here to help each other. I just thought you might get a good laugh out of that one.
T
TimWolve
yeah I had no clue there were different boards for the years, haha I did find this.. does this seem all legit ?
Tighten the sensor mounting bolt to 18 Nm (13 ft. lbs.)
Tighten the wheel hub to knuckle bolts to 180 Nm (133 ft. lbs.)
Tighten the nut to 240 Nm (177 ft. lbs.)
Tighten the brake hose clip bolt to 12 Nm (106 inch lbs.)
As an Amazon Associate we earn from qualifying purchases.
That's exactly what I believe to be the truth right there.
Gotcha12
