2004 Escalade License Plate Lights
FAT SS
Royal Palm Beach, FL
Noticed I had no license plate lights the other day. So I figured since I'm going to replace them I went with LED ones instead of stock ones. They don't work and I can't honestly say they worked before as I got the truck recently. I have checked the fuses under the hood and on the driver side panel and can't seem to find a blown one for them. Anyone have any idea where I should be looking? Does it have it's own fuse for just them?
Thanks in advance.
Sean
fiatdale
Houstons Best
Houston
First - check to make sure you have the LEDs installed correctly. LEDs will only work one way when plugged in.
fiatdale
Houstons Best
Houston
Try a standard bulb first. Make sure the plug is clean and solid. I don't think there is a fuse for those lights but I may be mistaken. If the plug looks good, trace the wires back and make sure it isn't broke. Also check the grounds for the junction block under the vehicle where the bumper light harness plugs in to.
GMT430guy
