2004 GMC Yukon automatic climate control module not working right after battery change.
MarioObstbaum
Hello everyone,
My auto climate control module not cooling nor changing modes in front area after changing the battery.
Blower works just fine as well as rear. Tried resetting twice without luck. Most likely need new module? Could all front blend doors go at the same time? Is there a module that you recommend?
Thanks for any help!
repairman54
NW NJ
On my '11 with auto HVAC when I did a starter replacement with battery disconnected it took at least 4 start up cycles for my front temp actuator to reset itself. It was stuck on full heat. No issues after 4 months now.
97ext
