JochenWoern
Understood, thanks. At this point I am still waiting for suggestions in regards to my power issue.
Thanks again.Some LED's are polarity sensitive just so you know, once you get power restored.
Tried that just now, unfortunately no change. Still no power.I would swap the relay with a known good one that's the same style (believe the A/C relay is the same). With the relay out, though, is there voltage to the relay socket? I'm not quite sure which terminal to check as I don't have a wiring diagram.
Yes, they do come on.Do your automatic headlights work, by that I mean do they come on automatically when it's dark enough or the sensor on top of the dash is covered?
Dash sensor does need to be kept clear. That sounds like it might be a reasonable explanation for lights on in daytime and no DTRL...Yes, they do come on.
On second thought, now I am thinking that they are on when it is bright outside, as I mentioned the other day that I thought the headlights were on when the wife came home from shopping in bright daylight. Which would mean the DRL's are obviously not coming on when the headlights are on.
Is maybe the sensor the culprit? I have a dashmat up there, may it is obstructing the sensor?
Am I correct in regards to the fuse and relay?
Thanks.
