2005 Denali Yukon won't take fuel- NOT THE EVAP SOLENOID
Dan Acosta
Your gas tank lines are plugged up with carbon beads from the charcoal canister, you need to remove the lines and blow the beads out.
This is the answer. Had to do mine. You have to drop the tank, and blow out all of the lines. (after charcoal canister has been replaced) Nearly impossible to remove all of the beads with the tank in place. At least it doesn't cost anything! The tahoe tank is actually fairly easy to drop. I have done it on a few different vehicles, and this was by far the easiest. Just make sure it doesnt have a too much fuel in it. Maybe 2hr total job.
Bmchobbit
