2005 yukon xl denali 6.0
TollKeeper
Brighton, CO
Next step would be to find out if they replaced the fuel pump by itself, or the fuel pump assembly.
TollKeeper
Brighton, CO
Depending on the shop, I can see them only replacing the pump. They can be had for around 134 bucks. Assemblies are quite a bit more expensive at the 400 mark..
ks03
Fool Excess Member
If you try to bump the key to bump over the engine, can you just bump it, or will it try to crank on its own for a few seconds?
ks03
Fool Excess Member
So my theory is that you might have to bump it to run the fuel pump. I’m curious if you bumped it, waited a few seconds, if it would then start normally without a long crank time
TollKeeper
Brighton, CO
So from here you will need to do a little bit of diagnostic work.
It sounds like the fuel pump might not be priming when the key is initialized.
To check this one, you would need to be under the truck, while someone else sits it the truck. Have them turn on the key, but do not engage the starting side of the ignition. Listen to see if the fuel pump primes.
TollKeeper
Brighton, CO
You could also go into your fuse bank, and swap the fuel pump relay with one from another location. See if it primes the fuel system KOEO (Key On, Engine Off).
Y
Yukonxljake
Great idea!
mplanet
