2006 gmc yukon xl slt air bag service light is on.
sonic_the_hedgeh
For the next time you have to clean them, undercoating might be a little messy to remove. I use paint on mine, both sides, since one of my threads is stripped and I had to put a bolt through.
I am using undercoating as I don't think after I cover them I am going to have to do that again for years. By then the undercoating will either flake off or need another coat. Hooefully
Sent from my CLT-L04 using Tapatalk
Fless
Super Moderator
Elev 5,280
Here this will bring your obd link MX plus back to life. Worked perfect here.dd106b8962b03161ecaf81d425239507.pnga03b9213e4fb8f80b6aa558246d20ba0.png
Sent from my LGL722DL using Tapatalk
Whap app are you using? I couldn't get chevrosys free to work with the Hoe and my OBDLink MX+ BT. I'll be trying Torque Lite, then maybe Torque Pro.
Woodblocker55
Woodblocker55
Really you don't need that app . install app that came with obdlink MX plus and install enhanced then find report . it tell you all codes. Mine came with GM .. So if you got for something else this might not work.
sonic_the_hedgeh
One of the ingredients needed for rust is oxygen. I did cover both sides completely so I Think if I ever have to do them again would be years. Although the ground cable I am thinking I will replace next year. The gauge on the ground cable looks small.
daddy g
