2006 tahoe misfire at idle and noise at idle
nonickatall
Germany
I would remove the valve covers to check if there a loose rocker arms, which can show a failed hydro lifter.
A clogged cat can cause misfire, because the engine can not get rid of the exhaust gas which leads into bad firing.
I would also exchange ignition coils, to check if the error alternate as well. Also you can do that with injectiors
D
Dustyhd05
Thanks for the ideas. I’m going to removed the rockers on number 7 and check and see if the lifters and cam is jacked because it is a hard miss on 7 and 2. I have swapped coils and injectors already and doesn’t move.
555hp
TahoeInterceptor
