2006 Z71 Tahoe
RVATahoe
Recently purchased and my headlights are loose as crap. Should there be weather stripping throughout the grill to help them mount correctly? If so I dont have any and would need to purchase this item . Any ideas??
Fosscore
No weather stripping on mine. Silly and I'm sure you have checked this, but make sure the pin that goes down from the top is actually engaging the hole at the bottom as well as the top. Maybe the OEM bracket is cracked somewhere and not holding the actual light housing securely? Just some thoughts to go with.
RVATahoe
RVATahoe
Nothings too crazy I willing to try just about anything. If the oem housing is cracked. I would need to purchase just housing or and entire new light?
Fosscore
Never seen just the housing. OEM lights not too much for complete assembly.
Maybe at this point think about some aftermarket lights for a change up to your front end unless you are set on OEM?
Post some pics of your truck. Guys can give you loads of further input with questions and a visual.
OhFourChevy
Houston Tx
OhFourChevy
Houston Tx
I'll let you know if it solves the wobbling issues, I won't have them installed till probably not this weekend since I'll be out of town, but some time next week or next weekend
RVATahoe
RVATahoe
OhFourChevy
Houston Tx
According to amazon they dont fit the 2006 tahoe.
I'd look it up on the website of the maker, because I've found a lot of things that "don't" fit my truck simply because they didn't want to input the info on amazon
treehan77
TYF Fiend
Crestview, FL
My depos (Yukon) don't wobble despite many other users having the issue. I've heard pong ping balls are the fix
Fosscore
The Ping pong balls do work. I know it's silly, but I put two in each side and that has worked pretty well. Still a great upgrade from OEM and the output is better. Looks? Hands down better.
reddirtdigger
