2007-2014? I need help identifying a hit and run vehicle
BangedUp
Three days ago, my pickup was hit in front of my house. By the broken pieces left behind, I can tell it was a GM vehicle. I also have a neighbors video showing it to be an SUV. It had the tall, vertical tail lights that first led me to believe it was a late model Escalade, but I've since found out that there are aftermarket lights to get the same look on earlier model GMCs and Chevys. Plus a neighbors security camera shows that it doesn't appear to have the vertical looking headlights, so I'm leaning more toward the GMC/Chevy.
Where I need help is in identifying some part numbers. I have a clear piece of the headlight assembly with the following on it: "SAE HRY215PP2AA2 07 DOT VOR SAE 17 8....."
I also have some black plastic pieces from the housing (reflective on the other side) with these markings;
"SAE -2(IN A CIRCLE)AIP2RST-88T" and a piece surrounding a bulb with "F.L.42.95" and "FL29..."
The last piece is angular black plastic with the following numbers: "15945787 Made in Canada, PPD SAE>PA66<P-563, CAV4"
The headlight numbers should be visible; but the other numbers should be visible if you had old parts laying around. I don't carry full coverage on a 20+ year old truck, so I'm left footing the bill unless I can track down the other vehicle; so any help in identifying what year and model these parts come from would be greatly appreciated. THANKS ! (the picture is a photo of the video, that I'm still trying to load...)IMG_2725.JPG
fat chance in hell unless they are local and you drive around the area and locate the vehicle in question, then it is still a uphill battle with any insurance company.
B
BangedUp
Oh, I know they are local. Video shows them coming out of a street that has no other outlet. There are only about 20-25 houses in that area.
gat0r
DFW
back of that pic, looks like escalade tail lights
cofferson
