2007 5.3 year compatibility
solli5pack
In GM’s schematics and breakout diagrams for purchasing parts, what is the component they list as the BCM?
j91z28d1
what are we talking about? ecm engine controller module. bcm body control module. tcm transmission control module?
if you wanna know what the bcm does, pick up a higher end scanner and open the body control module active tests. it does stuff on the body, like the horn, headlights, tail lights and door lock type stuff. as far as I know, no domestic based tuning software has even tried to crack the bcm. it's very annoying. while the import world hacks the bcm, the abs and everything is adjustable.
we act like if you adjust the traction control you're going to kill a bus load of nuns. it's silly but nothing in the bcm needs adjustments for a small increase in cubic inch
There's different types of glade plug-ins that 'disable' V4 mode, by somehow tricking the ecm into thinking that one or more of the conditions that would prevent V4 mode happens to be in effect.
The plug-in that tricks the TCM into 5speed mode would cost some MpGs.
Not sure that's the most clever way of avoiding V4 mode, long-term.
What IS clever about those plug-ins, is that while the plug-in is plugged in,
How does one get any realtime ecm / tcm data? How does one look at what the plug-in is actually doing?
(petethepug, V4 mode is tuned out of the ENGINE control module, not the body control module, even if other modules can say something to the engine control module to prevent V4 mode.)
you connect a obd splitter to monitor via the 2nd Y port
T
tjoyce81
352k with AFM is better than a lot without AFM lol impressive!
Years ago I blocked off the oil pressure relief in the oil pan, because the spring in it was failing. That increased the oil pressure and gave a more consistant pressure. The afm worked up until this issue. So, pretty sure this - along with 3000 oil and filter changes - contributed to the longevity.
I also run Quaker State full synthetic ultimate durability dexos 1 gen 3 - the one with the gold label.
It's the best on the market - but that's a serious pandoras box that I will leave closed...lol
BCM: body control module
ECM: engine control module
two completely different things
bcm is right under the dash, ecm is in the engine bay/compartment
they communicate to each other but are seperate things
both are somewhat universal in that they can be swapped from vehicle to vehicle (of same platform) as long as the correct vin data is programmed into them.
there may be differences of where say a escalade bcm and a lt tahoe bcm may not be interchangeable depending on a variety of things.
Marky Dissod
It's the best on the market - but that's a serious pandora's box that I will leave closed ...
I'll open it.
bobistheoilguy?
540ratblog?
I typically prefer Group IV full synthetics by Quaker State, Valvoline, Pennzoil Platinum (but NOT Ultra), Mobil1 Advanced, all 5W30 or 0W30.
Does Quaker State still make Ultimate Durability? Thought it was discontinued.
Im pretty sure my 2007 Tahoe LMG, vin0, engine cam broke (or cam chain broke?). Just shut off on highway, threw a code P0340. Removed cam sensor, stuck my finger in, rotated the engine by hand, and couldn't feel or see the reluctor wheel spinning. Verified by looking down the oil fill, rocker arms not moving.
So, with 352000 miles - completely stock - AFM operational until this - I am pulling the motor.
I plan on deleting the AFM, and installing the proper kit too do so - cam, block off plate, lifters, ecm delete, etc. etc.
Question I have - IF the engine I have cannot be used, what years can I use to replace the one in my 07 Tahoe?
Is there any 5.3s that do not have the AFM/DOD setup that will work?
The cam sensor is in the front cover, and the knock sensors are on the side of the block (easy accessed).
I am not looking for any type of performance upgrades (other than the afm delete) or larger displacement - just a job that can be easily done - because its getting cold and I'm doing this on the street lol.
Thanks for any help
A lot has been said already and your questions here have been answered. But, unless there is major internal damage, your LMG can be reused. At 352K miles, I would absolutely do a full rebuild, upgrading where desired (including deleting AFM). I wouldn't just replace the cam or timing chain or whatever broke. It's sure to need bearings and rings. This would be the longer route so if you wanna get it back in operation ASAP, swap in another engine, either a good used or rebuilt one. You can do whatever mods to it before you swap it in.
Dropping in a 6.0 or 6.2 to have a plug-and-play (or near it) upgrade would be fun, but you gotta consider the transmission. It's adequate behind the LMG, but will be stressed behind the HP/TQ of an upgraded engine.
In the GMT800 Upfitter Guide ground diagram, it's initialized as the TBC (apparently Truck Body Control):
CoyotesRUS
