2007 escalade high beams
have you checked all your fuses? it may be possible if there is a fuse out that the function may not work as designed but does work if the lights have power.
you can use a meter and just touch the outer contacts on the fuses for continuity, you do not have to pull them out to look.
Tssonebay
