2007 GMC Denali stalls after towing
wesyder
Eastvale
there is no 3/4 of the way on the gmt900's only degree's
mine would easily be 210-220 all the time just driving, albeit I drive like a madman, but once I added the tru-cool and a B&M deep pan it has not gone over 180 and usually hangs around 145-165 or less in the winter, trans lines & oil lines run separate from each other completely and run on opposite sides of the radiator.
Was speaking of my 05, that was the first test before my 08, have you stalled since your mods
I have never stalled even driving it 95mph up a 6% upgrade at 9000 feet for a extended period of time, basically forcing it to run hot. even then the transmission hung around 165, engine got warm maybe 220 or so. I know underhood temps are crazy hot on these trucks there is no where for it go, you could try taking off the shroud/guard around the wipers/hinge area and see if that helps, I might try that myself when I go get fireworks next month I have to pass over the sierra's and she's a steep *****
wesyder
Eastvale
Are you towing, mine hasn’t stalled after the cooler install
wesyder
Eastvale
That’s impressive, you drive your vehicle harder than guys towing 5-7k lbs
I might have burnt my cat's out again and now is not a good time prices are double and almost triple of what they normally should be.
**I did get it up to 12.7 a couple weeks ago driving 55-60 on a 2-lane packed highway that you just can't go any faster because it's a death trap.
wesyder
Eastvale
lol, I drive it harder than 99.99% of most people, if I go somewhere the only person getting there faster than me is if you are flying, these trucks are fine for that as long as you follow a severe duty maintenance schedule. I might have burnt my cat's out again and now is not a good time prices are double and almost triple of what they normally should be.
Yes they are, I am in cali as well
I went by the local muffler shop the other day and they said it's cheaper to buy the factory y pipe now than aftermarket, they said they quoted a guy $1800.00 to do his gm that same day. :eek:
Cincikid
Does anyone with an aftermarket trans cooler still have the stalling issue, I put a truecool 40k on my 05 and my 08 and neither have stalled since
I have one albeit not the 40k trucool, it's a derale about half the size.
Cincikid
What vehicle do you have? 2007-2008 6.2L? If so, no sure solution, since there are a number of potential causes ... but the low hot oil pressure/VVT problem is probably the cause 80% of the time. So the very first thing you should do is check what your oil pressure is at idle, when the engine is fully hot (better yet, after towing). You may need a scan tool that is capable of displaying oil pressure. Anything less than 20 PSI at hot idle may be a problem.
2008, when I tow I constantly watch my torque app which has oil pressure and temperature. When cruising, pressure stays around 38 to 40 PSI, when idling it stays anywhere between 15 to 20. Oil temperature was running usually between 230 to 240.
HD_LS
" 2008, when I tow I constantly watch my torque app which has oil pressure and temperature. When cruising, pressure stays around 38 to 40 PSI, when idling it stays anywhere between 15 to 20. Oil temperature was running usually between 230 to 240."
15-20 psi hot idle is too low, this makes it highly likely that your problem is caused by the typical VVT/ low hot oil pressure problem. You can read the cause and solution details earlier in this thread: https://www.tahoeyukonforum.com/thr...stalls-after-towing.73312/page-7#post-1519861
khg30
