So the Tahoe is running well. I still need to have some programming done, but I have an appointment with the most competent local guy I can find, so we'll see what he can do.
I have noticed that the gas mileage readout and the odometer on the dash are not correct. They are off by about a factor of 4 (it says I go about 2.8 miles, when I actually drive 10 and the mpg is terrible ~3.6). Is this internally calculated and stored in the dash cluster? or is it something that the ECM calculates and just feeds to the dash cluster?
I am debating swapping out the dash cluster since that's a simple thing. Also, I bought a shift lever with the +/- shifter on it so I'll work on that swap too. Anyone know if that is easy to do? I know the shifter bolts right up, but the plug is different. Not sure if the stock plug on the column can be modified (it has 4 wires) to fit the new column shifter (4 wires). The old shifter only has 2 wires coming off of it. Is there programming that needs to be done also? or if I modify the wiring, would it work and I could manually shift it?
Good news is that the actual gas mileage seems to be up with the new drivetrain and it definitely pulls a little better!
