2007 Yukon Denali Projector Retrofit
A
acandales001
He's looking to charge:
$550 for the "base" Hella conversion....plus:
$150 for halos top and bottom
$50 for blacked out buckets and reflective clear coating
$50 for custom upper shrouds (turn signals)
$250 for new OEM headlights
I got a great deal because he's also doing my Raptor and I was his first Yukon :)
AliBaba
Seattle, WA
I have a question for you all.... If you sand down the chrome inside the headlight is it black plastic of grey plastic???
THE YETI
Director of Operations
South FL
Should be gray if you sand it down. If you go down too far, might be black.
AliBaba
Seattle, WA
So it's actually made from black plastic?
Reason i ask is because i'm debating about having them chemically stripped down by a plating shop vs. sanding. I did it to my front chrome molding around my grill to paint black and the plastic is grey. This will help with better adhesion rather than dealing with sanding. If the inside is actually black then i may just leave it black plastic and not bother painting.
tony97218
