UPDATE!!!!!! I did find the demon... it was a bad ground in the harness the the lights and the rear hatch glass button are connected to. Im not sure if the splice was like that from the factory but i found it and fixed it. one thing that did suck is taking off the exterior cover to get to the harness, they put locktight on the studs from the factory so when you try to take off the nuts they end up getting locked up and the stud ends up breaking the plastic housing it sits in. Other than that it wasnt to bad to do. Now i have another demon to conqour. the rear door is electronic and will open and close with using the key fob the inside button or the button on the rear door. it opens just fine using any of those three things, but when tryin to close the door using any of the three things it does not close. you have to close it manually. Any suggestgions would be appriciated . Any body else have this issue?
