My 2008 HyHoe was running just find although I think the original 2008 hybrid battery was starting to go. I was not getting much distance running on just the battery... far shorter than usual. I parked it in the fall, I didn't disconnect the batteries expecting my wife to run the engine once a month to charge up everything. Well, she forgot..... 4 months later and after several periods of below zero weather, she went to start it.... its completely discharged. Not even the electric locks work, not even a dim dome light.
I'm not home yet - I'm still out of the country for another 2 months, still lots of winter left back at home, so I'm going to assume that the brand new $200+ AGM battery is now frozen and trashed. What about the NiMH hybrid batteries.... can they freeze and be damaged if they are discharged and then exposed to freezing temperatures? I'm assuming the hybrid battery pack will be discharged since from what I understand, the hybrid system maintains the charge on the 12v system. So if the 12V is dead, the 300V must be dead.... and frozen.
Lastly, I did a search in the forum but I didn't find an answer. Maybe I used the wrong search words.
Since the engine is started off the hybrid battery pack, is there a way to put a charge in the hybrid battery from a charger. I'm sure I could figure out something going the reverse engineering route taking the lid off the battery pack and build a 300V+ charger... but really before going that route, I'd like to see if there is a proper way, like what the dealer would do if a hybrid Tahoe came in with dead batteries. It would be a real stup!d design if the engine uses the hybrid battery pack, and the engine is the only way to charge the hybrid battery pack. There's gotta be a way of charging the hybrid pack to get the engine started.
I had plans to replace the hybrid pack.... now it looks like this spring/summer will be that job. But till I get to it, the Tahoe needs to be moved, so I need to get it started when I get home. In the mean time, I want to think about the options I have.
Any ideas on charging the 300V hybrid pack?
Thanks
Thanks
