2010 Chevy Tahoe Radar Hardwire
swacker69
Htown
All
I am wanting to hardwire my radar detector to my 2010 Tahoe. I have seen some posts here and there to wire it to the mirror harness and others to wire it to the inside of the upper console. I have tried to get the console down but no such luck - at least without having broken parts everywhere.
I am wanting to wire it to the mirror but am unsure of what two slots to use. I am aware that i will need to buy some sub D connectors and crimp them onto each wire.
If someone could help me out that would be great.
Greg
slk2k
Chicago-land, IL USA
Depends on where you want it installed. I hung mine from the rear-view mirror and used an invisicord to cable it in. I used a Country Joy mount for the mirror. You can make your own cable but I was very lazy that week ... :)
S
swacker69
Htown
Im going to use my own cable, do you know which pins to use on the mirror?
Bam
Abilene TX
Here you go! I used my "mad graphics skills :cool:" to show you where I tapped off to wire my radar detector into my '07. Not sure if it's the same for a '10 (but should be), so I would take a meter or test light to it to make sure.
I tapped off higher into the harness instead of at the plug...That is why you don't see any extra wiring in the picture.
Here is the end result: http://www.tahoeyukonforum.com/forum/showthread.php?p=223434#post223434
clayp
I just wired mine using a DIY invisicord - Radio Shack D-sub pins soldered to a phone cord. I used the above mirror plug wiring suggestions (Thanks BTW!) hot = pink, black = gnd.
Tssonebay
