2010 GMC Yukon major electrical issue
salyermarlin
2010 GMC Yukon 5.3L 170,***
Whenever you start up the car and first put it in drive the radio will start making a popping noise like you’re hooking/unhooking a aux cord and just go black for a minute and then come back on. While it’s off the lights on the dash start flashing, the doors keep locking/unlocking, headlights flashing/dimming, and the car will not go over around 10-15 MPH. I’ve tried my best to figure out what’s wrong but I’m not a mechanic and I can’t take it to one cause all the ones where I live always say it’s something major and charge you thousands and keep the car for weeks and barely touch it before giving it back to you and it won’t even be fixed. So I need help so I can fix it myself. This is my wife’s car and she uses it to take our son to school everyday so I need this fixed ASAP
S
salyermarlin
I forgot to mention that I have changed the 175 mega fuse and the oil pressure sensor is bad but both are very recent and this issue has been going on for months
Trouble codes? Do you have a code reader to pull engine and other internal codes?
How old is the battery and if you put a voltmeter on it in the morning, what does the voltage say?
This reads like a connection issue. Either your battery cables are corroded, your battery is bad in some way, and or your grounds are corroded and need cleaning/replacing.
Less likely but still could be is that your Body Control Module needs replacing.
Knowing the codes and voltage and is going to get us started on finding the problem.
S
salyermarlin
Only codes are for the oil pressure sensor. I’ve had the battery checked several times to make sure but it’s been maybe a month and a half since the last time but everytime it was checked it was great. Not sure exactly how old it is though. Doesn’t look to be old enough to be bad. I am going to replace the battery cables ASAP to see if that helps it though. Thank you
CiscoKid
Virginia
Had the exact same thing happen with my 2014 Yukon XL. Had the negative battery cable replaced and it has been trouble free since. Probably like seven years or more. The negative cable may look fine, but I read somewhere that they corrode from the inside out. Best of luck!
chevyguy02
