2010 vs 2011 Yukon Denali
soulsea
Bar
Hi ... :)
So I'm doing some research on AOL Autos on the differences between the 10 and 11 model year SWB Denali AWD, and I'm seeing these numbers:
Electronic Stability System:
10: std
11: StabiliTrak w/Proactive Roll Avoidance
Fuel Economy:
10: 13/20
11: 13/18
0-60:
10: 6.1
11: 6.4
Also better 1/4 mile time and speed, and slalom speed on the 10
Curb Weight:
10: 5,732 lbs.
11: 5,817 lbs.
And this is the big one!
Front Hip room:
10: 64.4 "
11: 60.3 "
So far as I can tell, other than a StabiliTrak upgrade adding a little weight on the 11, it is slower, less agile, worse on fuel economy, and has 4" less hip room than its 10 model year counterpart.
Are there some other upgrades from the 10 to the 11 that I'm not seeing that make up for this seeming downgrade?
I'm a little confused as to how the 10 would in fact be a superior vehicle than a newer 11. :think:
Thoughts?
http://autos.aol.com/cars-compare?c...0GMS033A0&v2=USC00GMS033A0&v3=&v4=&v5=&spAd=y
THE YETI
Director of Operations
South FL
Did u check ur old thread? A very courteous member has found you quite a few 2009 6.2L Black on Black Hoe's... :D
soulsea
soulsea
Bar
Orly?
Here I go ...
---------- Post added at 05:02 PM ---------- Previous post was at 04:58 PM ----------
So yeah, do you haz Denali related info?
03tahoe2012
Plano,TX
you know what? im going to have to go with the 2010. but its up to you and YOUR needs.
THE YETI
South FL
ur 09 has less than 25k miles? :hmm: If it was a Sierra Denali, i'd be in!
Aviator_78
